Axes, what do you know about them ?
rodp
A bad influence
Post by rodp » 06 Aug 2016, 18:00
So, thinking of getting a relatively light hand axe for occasional use clearing branches etc in a wood. I would be looking for one that takes and holds a very good edge and well balanced. Would I be better buying an old one off ebay in the assumption old Sheffield or Swedish steel was good? Or do I look at a modern one ?
What's about, and, how much ?
Re: Axes, what do you know about them ?
Post by sunndog » 06 Aug 2016, 18:54
Assuming you don't mind tidying up the edge have a look at hultafors or husqvarna branded axes. Mostly produced by hults bruk and re-branded
The finish is a little rough but decent steel and hafts....all on ebay mate
rodp
A bad influence
Post by rodp » 06 Aug 2016, 19:28
sunndog wrote:Assuming you don't mind tidying up the edge have a look at hultafors or husqvarna branded axes. Mostly produced by hults bruk and re-branded
Cheers Adam , I knew you'd know :thumbup:
rodp
A bad influence
Post by rodp » 06 Aug 2016, 19:53
Right then, had a quick look and the hultafors are about twice the price of the Husqvarna, what's the difference? If the steel is the same and it's just rough edges or poorer finish on the Husky then I'm not too bothered, however, if the steel on the Hultafor's is a better quality then I'll go for one of those.
Is there anywhere that actually lists the steel spec?
Post by sunndog » 06 Aug 2016, 20:03
Go for the husky mate, odds are they came off the production line at the same time but the hultafors got an extra 10 minutes of 'finishing' time
I'v got a husky branded small splitting axe that i re-ground to use on my falling belt and its fine mate
rodp
A bad influence
Post by rodp » 06 Aug 2016, 20:16
Cheers Adam :thumbup:
rodp
A bad influence
Post by rodp » 06 Aug 2016, 20:34
Right, ordered a Husky and should be here mid week. Now, about this tidying up, I need to (A) know what to do (just clean it up, file / grind flattish?), and (B) see a pic of yours. Then I'll post a pic of mine and we can have Axe porn :thumbup:
:lol:
Post by sunndog » 06 Aug 2016, 20:47
Which one did you get?. it will be usable when you get it, its just the grinds will probably be a little uneven and not the sharpest thing you've ever seen
You can just work it with files, or 2 minutes on a belt sander
Pic of mine? Well i'v got a dozen or so axes so i'll gather a few tomorrow
rodp
A bad influence
Post by rodp » 06 Aug 2016, 21:36
sunndog wrote:Which one did you get?. it will be usable when you get it, its just the grinds will probably be a little uneven and not the sharpest thing you've ever seen
Hence the avatar ? :crazy:
:lol:
Post by sunndog » 06 Aug 2016, 21:42
My sig on another forum just says "uncle chop chop" :lol:
