17hmr vs 223 trajectory
paulham
Post by paulham » 25 Oct 2013, 16:26
Hey, wondering if some one can help.
I've got the photon zeroed on my 17hmr with quick release weaver mounts, my 223 also has weaver bases, if I was to put the photon onto the 223, is there a way to know how far the zero would be out?
V8 90
Re: 17hmr vs 223 trajectory
Post by V8 90 » 25 Oct 2013, 17:29
Sure is - aim at a target at desired distance & hey presto POI clearly shows how far out it is ;) ;)
paulham
Post by paulham » 25 Oct 2013, 17:30
Before going out.
I would like to get near enough before I go out.
V8 90
Post by V8 90 » 25 Oct 2013, 17:44
Take the bolt from your rifle - put your rifle on a maintenance bench or a bean bag or whatever so it's held firm - point the rifle at a wall or fence or whatever you have at around 15m - pick out a knot or small mark & centralise the mark by looking down the barrel from the breech - now, without moving your rifle look through the scope & see where the dot is aiming - I did this with my .22lr & my Hmr 2 weeks ago, when I fired at my zeroing targets I was within 1" :thumbup:
fizzbangwhallop
Post by fizzbangwhallop » 25 Oct 2013, 17:50
Not really a way around it...... back to basics and bore-sight it as V8 says to get you on the paper...... I'd also set a spirit level across the turrets to level the rifle/'scope. The your first shots at 25m where you want to be around 1 to 1.5" low then out to 100m. Don't forget the number of clicks at 25 is 4 times the 100 click.
Count the clicks if you're intending to switch the Photon between the 2 rifles. But bear in mind that quality 'scopes will have repeatability on the clicks but I don't know if the Photon falls into that bracket.... you'll just have to suck it and see. You could try the usual..... fire a shot, x clicks right, shot, x clicks down, shot, x clicks left, shot, x clicks up, shot and with luck you'll have a square and the last shot on the first.
Simples.
(He said.)
Have fun. :thumbup:
8-)
paulham
Post by paulham » 25 Oct 2013, 17:57
Cheers guys, ill have to do it the pratical way, I was hoping for a nice confusing mathematical way. Lol
Paul
paulham
Post by paulham » 26 Oct 2013, 10:19
Was going to write this up last night when I got back but I fell asleep.
So I walked up to the abandoned pickup truck which is at the top of the field at the muckheap, it gives a nice table to put all my kit on, and I shoot from the roof down a hill to a target set up on the fence 89meters from my shooting position. The land steeply rolls up behind this so I know all is safe.
I swapped the photon from the 17HMR and onto the .223, I took 2 shots at the target and went down to check my shot placement. No marks at all, not good.
I took the target back with me and set it up at 40 meters (approximately, my range finder got stolen from my car, so I try to range find using my iPhone and a its GPS)
At 40meters the shot was an iPhone length high (thinking about it now, I had a tape measure in my bag, haha) so 11.5cm high.
Onto a quick zero chart , I worked out that 11.5cm high, at 40meters, on a 1/4" moa scope equals to 37 clicks down.
Then I went onto Ballistic AE iPhone app, set up the zero for 40 meters, then worked out how many clicks were required to zero at 89meters = 14 clicks down
Total 37 + 14 clicks down = 51
Then I did a test shot at 89m, 1.5" low, not bad for abit of maths, 7 clicks up and 8 clicks right and we were bang on :).
I took the photon off the 223 and put it back on the HMR, reverted the clicks and took 3 shots, all as expected.
Put the day scope back on the 223, took 1 shot, bang on.
So I'm happy. At any time I can swap over the photon between my rifles and know where the shot will hit.
