New to the forum
tdea1388
New to the forum
Post by tdea1388 » 29 Jul 2014, 13:46
Hello everyone I am new on here and really not sure I am doing this correctly, but here goes..... I am currently trying to do a scopeless build and I have purchased pretty much all my items from the rolaids and the advise from guys on this site.. But I am still confused about the lenses, Should everything be manual like the aorature and focus?
What does the lens mean when it is a 135mm auto with manual focus the F=2.8? Also will this work on the EJ230?
punky
Re: New to the forum
Post by punky » 29 Jul 2014, 13:51
Hi and welcome aboard the good ship lol
One life live it!!!!!!
tdea1388
Post by tdea1388 » 29 Jul 2014, 14:48
Thank you, You guys have a lot of interesting topics on here. I have honestly been reading for days and still have a long way to go... LOL
Post by phoenix » 29 Jul 2014, 15:01
tdea1388 wrote:Hello everyone I am new on here and really not sure I am doing this correctly, but here goes..... I am currently trying to do a scopeless build and I have purchased pretty much all my items from the rolaids and the advise from guys on this site.. But I am still confused about the lenses, Should everything be manual like the aorature and focus?
It mean the lens has a focal length of 135mm with a maximum aperture of f2.8.
The lens is manually focussed, but when connected to a suitable camera, the aperture will be adjusted automatically.
In a scopeless build the auto aperture function won't work, so aperture adjustment will have to be done manually
135mm with an EJ230 will give you a lot of magnification, but an aperture of f2.8 won't let in a huge amount of light so the image you get may not be very bright and will probably require quite a lot of IR illumination.
tdea1388
Post by tdea1388 » 29 Jul 2014, 15:09
Thank you Bruce, That helps a lot. There is so much info on here it can make your head swim trying to understand it all... :crazy:
Torchwood
Post by Torchwood » 29 Jul 2014, 16:25
Hi and wellcome aboard.
If you are looking at m42 lenses, they quite often referred to as auto, however they have a switch for auto/manual aperture. For scopeless you would use the manual setting. So both focus and aperture is set manually. As Bruce said, 2.8 apperture is quite small. You would need a lot of IR. What sort of distance are you shooting. 135mm is really center fire ranges. You can get a 135mm 1.8 lens. But that would be around £200.
You would also need a adaptor to use these lenses with ej230. Let us know how far you are with your shopping list, so someone can give you some advice for nitty gritty.
Toni
tdea1388
Post by tdea1388 » 29 Jul 2014, 18:03
I have Bought the rolaids camera housing with the c mount adaptor, the ej230 camera, The hd monitor, I also have the video glasses,6800mah battery pack, power splitter for the screen and camera, and the scope mounts to mount it.... I think unless I am missing something all that is left is the lens. I plan on using this with a .22 mag and a .243 rifle. Is there any thing else I may be missing?
Also since the aperture has to be open all the way, could you just remove it all together? Probably a dumb question, I know nothing about lenes
I want to thank (Some Bloke) Dave for his impartial explanation of the two camera housing, His and rolands.
tdea1388
Post by tdea1388 » 29 Jul 2014, 18:08
I may be better off with a 75mm instead of the 135mm...???????
Post by some bloke » 29 Jul 2014, 19:25
tdea1388 wrote:I may be better off with a 75mm instead of the 135mm...???????
105mm is a 'halfway house'
What ya shooting at what range?
Torchwood
Post by Torchwood » 29 Jul 2014, 19:36
C mount Cosmicar 75mm 1.4 is a fantastic lens, you don't need a daptor to mount it. If you deside on a m42 lens (SLR), you would need a adaptor.
The aperture would be handy if using the setup in daytime. I don't think it's that easy to remove them on m42 lenses. But why should you.
Toni
