36mm high mounts wanted
Torchwood
Post by Torchwood » 18 Feb 2015, 21:27
Looking for a unusuall but available 36mm scope mount. Been looking around. Just can't find anything at a reasonable prices. Is there a budget version? If you have a source, let us know please.
Toni
Hestbec
Re: 36mm high mounts wanted
Post by Hestbec » 19 Feb 2015, 21:02
The highest i know of is this 30mm
If it doesn't have to be one piece, you could combine a 2-slot picatinny riser with a scope mount?
Torchwood
Post by Torchwood » 19 Feb 2015, 21:37
I may have phrased it wrong. :angel:
It's actualy the size of the ring I'm on about. 36mm . The norm is 25mm or 30mm. I need a 36mm rings. They are about, £85 for a pair. That's too much for a project. Will be needing only one.
http://www.swillingtonshootingsupplies. ... pe-Mounts/
Toni
andybig
Post by andybig » 19 Feb 2015, 21:40
Whats it for Toni?
Is it a mount for an ir?
How about 35mm rings and a bit of sand paper :lol:
http://www.ebay.co.uk/itm/Vector-Optics ... 19d8ebd026
chas
Banned again
Post by chas » 19 Feb 2015, 22:46
This might sound a right bodge but have to admit I've done it myself.
If you get some really cheap 30mm rings, the ones that bend easily, you can get a piece of metal tube of the required diameter in your case 36mm and put the lot in a vice to spread the 30mm to 36 diameter.
The screw holes won't line up anymore due to then being splayed, but a quick drill through and a longer bolts did the trick for me, doesn't look pretty but if just for an experiment it might serve a purpose.
Effluent in many languages.
Torchwood
Post by Torchwood » 19 Feb 2015, 22:52
Thanks chas. Yes it can be done. This is for a rifle sight. Mini broom. :D so in need a good hold.
You are a star Andy. A bit of sand paper will do the trick. :thumbup: I didn't think about 35mm. :o
Will buy the ebay pair. You never know, some one will be looking for one soon. :D
Toni
andybig
Post by andybig » 19 Feb 2015, 23:01
I did find one other set on ebay but they were about £5 more and they looked a bit thin and flimsy.
Whats the OD of the t67 with the two batteries?
I know its bigger than 30mm.
So someone will probably snap your hand off even if they need to fill the gap with electrical tape.
