Chaps ..
LASER GENETICS ND-3 Laser designator torch
In as new condtion , cost me £115 , so grab a bargain at £80
Any trail or inspection welcome , im in surrey
The web blurb from the web ..
The compact ND-3® Laser Designator
The ND-3® Laser Designator uses patented technology to create true night vision and turns your scoped rifle into a night hunter. Combining a powerful, green laser diode and a precision optical collimator, the ND-3® pairs with your scope and allows you to cast a bright beam of green laser light to fully illuminate targets up to 250 yards. Rotating the collimator ring to minimum creates a bright micro beam of green laser light visible up to 3 miles and rotating the same collimator to a wider setting it can be used as a light source when hiking or following a trail.
Excellent source of illumination for Hunting, Fishing and Shooting Sports
If you are an outdoor enthusiast who spends most of your time in warmer climates, such as 40 degrees Fahrenheit or above, we recommend using the standard ND-3® or ND-5® series of products. However, if you are mostly spending your time in rough and cold weather conditions in temperatures 40˚ F and below and looking for a compact, light weight and reliable source of light, then look for the ND-3 Subzero™ line of products.
Why Green Laser?
Green light is the most visible to the human eye (See Chart) and requires the least amount of eye adjustment at night. An eye that has adapted to daytime conditions generally has a maximum sensitivity around 555nm. Compared to the color red which optical spectrum is around 630 – 650nm our eye is closer to the Green region of the optical spectrum at 510 - 530nm.
Animal eyes are intensely illuminated by green laser light and clearly visible at extended distances when viewed through optics. For optimum night vision for hunting, pair the ND3 with a high quality variable power scope having a 40mm or larger objective lens providing maximum light transmission. The included ND3 mounting system for 1” tubes provides full adjustment for windage and elevation for scope alignment. Additional mounts for binocular, spotting scopes and weaver rails are included.
Hunting and Wildlife Observation: -Allows wildlife viewing at long distance. Laser beam is visible up to 3 miles providing pin point rescue location Beam diameter is easily adjusted to be a light source for night hiking. 7 hour battery life. ND•3 - SPECIFICATIONS
•PRECISION MACHINED FROM HIGH TECH ALUMINUM
•BLACK MATTE ANODIZED FINISH
•FULLY O-RING SEALED FOR DUST AND WATER
•FULLY MULTI COATED OPTICAL LENS SYSTEM
•NITROGEN CHARGED FOR ANTI-FOG
•1” TUBE ADAPTS TO MANY MOUNTING SYSTEMS
•DIMENSIONS: 6.10”L X 1.25” DIA. X 1.0” DIA. TUBE
•WEIGHT: 5.34 OZ.
•POWER SUPPLY: 1 CR123A BATTERY (INCLUDED)
•ROTARY OPTICAL BEAM COLLIMATOR- ALLOWS QUICK ADJUSTMENT OF BEAM DIAMETER AND INTENSITY
•532nm LASER LIGHT FREQUENCY- EASIEST LIGHT FOR THE HUMAN EYE TO SEE (SEE CHART)
•AMPLIFIED COHERENT LIGHT- MOST EFFICIENT LIGHT FOR LONG DISTANCE ILLUMINATION
•OUTPUT POWER: 18mW
•RANGE: UP TO 3.0 MILES
(Range might vary depending on weather conditions)
•1 YEAR WARRANTY
•CLASS 2M LASER PRODUCT
<18mW 532nm CW -
INCLUDED ACCESSORIESOPTIONAL ACCESSORIES
WEAVER STYLE RING
BINOCULAR & SPOTTING
SCOPE MOUNT 1" SCOPE MOUNT
ADJUSTABLE ELEVATION
AND WINDAGE
1 CR 123A LITHIUM BATTERY • PADDED CASE
LASER GENETICS ND -3 Torch ..
bwganbrain
Re: LASER GENETICS ND -3 Torch ..
cant do it for £60 ,,
£75 including postage is the best .
cheers
cheers
