Used third generation image intensifier tube, I have photos I can mail if required.
The tube lights up bright and has good gain and generally works very well, no flickering or power supply issues etc, their is a blemish at around 2 o'clock position (white spot - see photos), in approximate area 'zone 2'
If you live local to Essex you are more than welcome to view the tube in use
Postage offered by Royal Mail special delivery, no returns - it is a used tube.
£400 posted
MX10130 GEN 3 TUBE
jameshardie
Re: MX10130 GEN 3 TUBE
Should add it is a MX10130 B/UV tube
For those interested, that makes it a non inverting Omni II Gen III tube from around 1985-1990. Minimum 45 lp/mm, signal to noise minimum 16.2, photo sensitivity 1000ua/lm, gain 40000 to 70000. Basically low end gen II resolution, but high end sensitivity and light amplification.
