I have had a sort out in the shed and got together a big box of bits from past projects and bits that i have bought but never used , with work the way it is at the moment these would probably just stay in the draws forever so i may as well see if anybody wants them , i wont split any of this its all or nothing , there is too much to list individually so i will just list the main bits.
Pentax 55mm f1.8 lens , seems to be in good condition , pk fitting (i think)
kowa zoom lens 12.5-75mm c mount (i tried this once but wasnt impressed i think it may need a good clean)
Helios 44mm m42 , looks quite old and i dont remember ever using it.
probably another half a dozen assorted m12 and c mount cctv lenses
Home built spotter using a camcorder viewfinder , 18650 battery holder and cheapy camera , i havent tried this at night but it worked fine in the garden during the day.
couple of board cams and a nice little kt&c ex20b camera that came built for using m9 lenses so i chopped the casing about and fitted an m12 lens holder its a b/w no osd camera that works well and is very small
one of the small viewfinders with the built in voltage droppers igor has been selling on here recently , i bought this made sure it worked then just chucked it in a draw
canon camcorder viewfinder (never tested)
vf-c2 viewfinder (this worked fine till i tried using a voltage dropper that was wired wrong so i am fairly sure the board is fried , the cable and lens should be ok though)
2 x T20 pills , one is a standard white and the other has a red led fitted
led tech red led (never opened)
2 x prisms
3 x chinese blue batteries and chargers (a couple have had the on/off switches removed , these work but i dont know how well)
3 or 4 sunshades
2 x m12-c mount adaptors
big bag of switches , sockets , plugs cables and other bits and pieces
SOLD
http://i1336.photobucket.com/albums/o66 ... 0pikel.jpg
http://i1336.photobucket.com/albums/o66 ... b9d9wk.jpg
http://i1336.photobucket.com/albums/o66 ... riwrrx.jpg
http://i1336.photobucket.com/albums/o66 ... fnd2z6.jpg
http://i1336.photobucket.com/albums/o66 ... vgv4mu.jpg
http://i1336.photobucket.com/albums/o66 ... nva6te.jpg
http://i1336.photobucket.com/albums/o66 ... vuhcip.jpg
http://i1336.photobucket.com/albums/o66 ... wntgwp.jpg
http://i1336.photobucket.com/albums/o66 ... ifuhch.jpg
http://i1336.photobucket.com/albums/o66 ... zsbbip.jpg
