These have a very robust saddle clamp for a compact (single cell) 25mm/1" tubed illuminator, not supplied: Spotters don't need as much IR as add-on rigs, and most NV users will have a small one tucked away somewhere. All you will need to use is a T38 - or even a humble 501b if it has the new 'AS LED in it.
Find more detailed information about them in this thread:
http://nightvisionforumuk.com/viewtopic ... 64#p107564
How to use them:
https://www.youtube.com/watch?v=YkY0F362qkY
https://www.youtube.com/watch?v=5cYTzL-OiyY
Some of its performance:
https://www.youtube.com/watch?v=Dk38jzMj0w0
https://www.youtube.com/watch?v=b3JODhah--k
What you get in the box:
An E700 camera - modified with the neck milled back to suit C mount lenses with a three pin cable and plug soldered to the original cable, pre-fitted into the main spotter body. You may wish to invert the camera/spotter so the lid is not sealed - user can seal it with thick grease or sealant.
A 50mm F1.4 C mount lens will be supplied by default as best option for mixed fox and rabbit spotting. For rabbit range only spotting a 35mm lens or 25mm lens for wider FOV's can be specified with the order.
Four M4x40 cap head screws to secure the torch clamp in counter bored holes: You need to source a 1" or 25mm torch tubed illuminator.
A 5" HD LCD monitor with modified cable and plug - to be placed somewhere convenient on the dash board - Blutack can be used if needed.
4 self adhesive cable tidies so you can leave the cabling in place - but un-plug the main body.
A 12volt car accessory plug with soldered cabling and connectors to power both the monitor and the camera.
A 3 x 1 metre extension cables to allow a myriad of monitor fitting locations.
A A heavy duty suction mount assembly with a modified stainless steel ball end stud and nut to bolt to the spotter body. You will need an 11mm or 7/16" spanner - or pliers if you are not so equipped.
A rain shelter and fixing bolt.
Price is £200 + £10 RMSD to UK addresses, or collect.
A one off special edition (without the illuminator or bench test cigar lighter socket) is also available with a 5" DVR and custom made AV IN cable to replace the regular 5" monitor, priced at £260 + RMSD UK, or collect:
