£210 + £10 RMSD or collect.
Carriers are:
A solid machined handle with a lanyard hole in it.
A Suction mount to fit the roof or window of your truck - like the lower one of these:
The spotter is powered by 2 18650 batteries - not supplied, and most NV users will already have a spare illuminator that can be fitted to it with a weaver based scope mount. That allows the illuminator to be shimmed or otherwise aimed high so the foreground is less likely to be washed out and the camera AGC can continue to see further rather than try to shutter out any excessive foreground light bloom.
The 5" monitor has a brightness control, with cabling that allows it to be moved into a truck (with an extension cable) or the grass if laying up at a bait station. Shown here with a used SLR 50mm lens for general purpose fox and rabbiting magnification.
Or just shift the monitor onto the grass if laying up at a bait station etc:
The 5" monitor forms the lid of the box - this is how it is removed: https://www.youtube.com/watch?v=rNOhhMY1UsE
Additional 1 meter extension cables can be supplied at £5 each.
