Be warned there are some 5" monitors that initially LOOK identical, but if they have screws in the corners of the rear cover they will not fit these boxes as they are too wide.
The boxes are now 52mm total inside depth and the monitor seats/pivot pegs are solvent welded to 9.5mm deep, the bulge on the rear of 5" monitors adds about 7mm to that giving an available clear space of about 36mm behind the monitor to easily accommodate almost any batteries likely to be used.
Use for add on rigs...
And spotters...
OOPS, I got a bit carried away here- thats for next weeks something lol
This is how the monitor is fitted or removed for battery changes or other access reasons: DO NOT PULL THE SUN SCREEN because it WILL break off!
Priced at £23 + £7 RMSD for any single order quantity.
