Buyer supplies the 3 flat top 18650's needed to operate it.
Because it can sometimes be used without an illuminator there are two switches. The lower one works just like the tail switch of the torch, half presses to change the power level and full press to turn on. The upper one powers the cam and monitor. Switches have a visual reference - if the IR button is 'in' you left it on.
The entire single cell torch body is used and if you are ever unfortunate enough to run over the spotter for example it can be removed and used with the tail cap that is supplied with it... assuming you are strong enough to defeat the Loctite retainer. LOL.
It will be supplied as default with a 50mm lens that is ideal for bunny and fox - but at the expense of being impractical for close range use such as ratting ETC. A 25mm alternative lens can be supplied if specified but I would recommend you just buy one from ebay for not much money if you prefer a wide angle view.
The machined handle has a hole in it for a lanyard - the production one's will have a minor revision of the handle.
There is an optial delusion here because the photo is taken at an angle, the lens is directly above the illuminator. The handle has a swivel action - more about that with the production ones.
This is how you fit and replace the batteries:
Price is £240 collected or £250 posted RMSD to UK postcodes.
