Versatile spotters with free roof magnet. Out of stock till next week
Post by some bloke » 30 Nov 2015, 16:57
Here is one of my new versatile spotters with 5" HD monitors and genuine KPC E700 low light cameras. It can be ordered with a T30 AS IR led - or with a Black Sun T50 IR installed in it.
Because the superior camera can sometimes be used in a spotter without an illuminator there are two separate circuits, each with its own latching switch that have a momentary action if needed. The upper switch powers only the cam and monitor. The lower switch is for the illuminator and works just like the tail switch of the torch: Half press to change the power level and full press to lock on. Both switches have a visual reference - if the IR button is 'in' you left it on. The single IR battery lasts the same as an AS led in a single cell 'T' torch. Both switches can of course be turned on at the same time with two fingers.
The entire single cell torch body is used and if you are ever unfortunate enough to run over the spotter it can be removed and used with the tail cap that is supplied with it... assuming you are strong enough to defeat the Loctite retainer. :angel:
It will be supplied as default with a 50mm lens that is ideal for bunny and fox - at the expense of being too zoomed in for close range use such as ratting ETC. A 25mm alternative lens can be supplied if specified but I would recommend you just buy one from ebay for usually under £20 if you prefer a wide angle view so you can optimise for each role.
The machined handle is chunkier than my older one's to better fill the hand and has a smaller section to wrap a finger round so it requires less grip to retain it. It has a twist grip action that tensions a steel band around the torch body to allow a degree of articulation to account for bonnet drops etc: Unscrew it to slacken its tension, rotate the unit as required then lightly screw it up - it only needs nipping up gently.
It comes with a FREE gift: There is an M6 threaded insert in the base of the handle that allows a FREE powerful rubberised magnet to be screwed into it-time will tell if they work out. The handle is very close to the units balance point. If the M6 thread/magnet idea doesn't work out for any reason I reserve the right to remove this aspect, and they have not been charged for. Fitting the insert has however gone better than I anticipated and it seems very solid:
I know some shooters like to get on it like a car bonnet, but perhaps not to this extreme. :angel:
Or maybe use a metal post or building:
Or a farm gate you happen to be hiding behind or resting on:
The monitor can be shifted a few inches away from the unit - or much further away, perhaps inside the truck using 1 meter extension cables at £5 each if ordered with the spotter. The very powerful rubber based magnet can be unscrewed from the base of the handle.
Two illuminator options are available, A T38 that is suitable for most of us - or a Black Sun T50 for improved bragging rights. :P
Buyer supplies the 3 flat top 18650's needed to operate it, I generally use 'free' one's rescued from duff laptop batteries.
A block cable connector has been used for the final part of the IR LED circuit so it is easily removed by the user in case it fails or a new LED spec becomes available rather than send it back to me for repair. It is inserted into the torch body and can be fetched out with a hook or fine nose pliers etc. :
This is how you fit and replace the batteries:
A small video:
https://www.youtube.com/watch?v=CTLdsDV6PNU
Price is £250 collected or £260 posted RMSD to UK postcodes for a T38 AS IR equipped model.
Price is £270 collected or £280 posted RMSD to UK postcodes for a Black Sun T50 AS IR model.
I'll be adding to this as and when updates are made.
ShropshireSam
Re: New versatile 5" monitor spotters with free roof magnet.
Post by ShropshireSam » 06 Dec 2015, 21:58
Looks just what I have been waiting for.....I will PM you with an order.
Post by some bloke » 07 Dec 2015, 02:03
ShropshireSam wrote:Looks just what I have been waiting for.....I will PM you with an order.
A Black Sun variant sold subject to the usual - thanks Sam. :thumbup:
I'll re list this as a T38 only until I have made up another one
ShropshireSam
Re: New versatile 5" monitor spotters with free roof magnet. SOLD
Post by ShropshireSam » 10 Dec 2015, 17:33
A fast delivery and spotter just as described. Looks and feels a quality build. Had my first test last night. Could spot rabbits easily and they were not disturbed as I watched them from 40-100 yards. As I approached closer on foot most squat down.
The rubberised magnet is powerful enough to hold the spotter firmly to any metal. Will be ideal spotter for my mate to rifle from the sunroof as can be just stuck on the truck roof whilst the shot is taken.
Post by some bloke » 18 Dec 2015, 12:17
I tried guys... I really really tried but after getting quite a few requests for a video - and with the weather being unseasonably fine between showers I just HAD to do it. :P
https://youtu.be/sbLNOu0UaGk
Re: Versatile spotters with free roof magnet. Out of stock till next week
Post by some bloke » 19 Dec 2015, 12:16
Both sold. Will re-list individually when replacements are available.
