Pulsar DFA75 - Night Vision Scope Front attachment
chriswilson_m3
Post by chriswilson_m3 » 17 Jan 2016, 12:37
Having used this on all of my day rifles I have now moved to a dedicated Night vision setup, so I can't justify keeping it. It is a completely fantastic bit of kit is mint condition, and turns you day rifle into a nightvision unit without having to change the scope or re-zero. I think what I find particularly surprising about this unit is that you can put in on and take if off multiple times, and it keeps the zero each time.
In addition to the unit with came with the IR illuminator, I have bought the monocular attachment (costing £85) so that you can use it as a spotting scope and also every type of ring adapter so that it will fit on all scopes. costing £120 when bought. It comes with 2 battery holders so you can swap quickly if the battery dies, and also a remote control and a lead for linking it to a video recorder.
Inserts for 42mm adapter are: 47mm, 48mm, 49mm and 50mm
Inserts for 50mm adapter are: 55mm, 56mm, 57mm, 58mm and 59mm
Inserts for 56mm adapter are: 60mm, 61mm, 62mm, 63mm, 64mm and 65mm All included.
Also, to be clear, this is the 2nd generation model, so it is the very latest model!!
I am selling the whole lot for £800 - no offers please. This is everything you could need for any rifle or hand held NV setup.
Here is the official spec and some links:
http://www.scottcountry.co.uk/products- ... t-5139.htm
http://www.scottcountry.co.uk/products- ... d-5525.htm
Pulsar has redefined the night vision benchmark with the introduction of the Forward DFA Digital NV Attachment, the World's first and only digital night vision module that attaches to the front of a daylight riflescope.
With a CCD chip that is used in digital deep space astronomy, the Pulsar Forward DFA75 delivers ultra-sharp images in very challenging lighting conditions. In short, this product heralds a new step forward in hunting optics.
This advanced system features:
50 lp/mm system resolution
SumLight signal processing
Precision ground, fully multi-coated optics
50mm / f1.0 objective lens
High resolution 640x480 OLED display
1x power when fitted to a riflescope
Attachable 915nm 'stealth' Laser IR Illuminator with three-step power adjustment and focusing. Certified to meet Class 1 laser safety
Video-out socket for recording the shot to a Newton CVR640, Yukon MPR or similar
Programmable wireless remote control
Huge illumination operation range 0.00004lux - 30,000lux,. Can be used in daylight for recording your shot
Self-contained (4x AA batteries) or external power supply (Pulsar EPS3 and EPS5 battery pack)
Impact resistant glass impregnated composite body
Lightweight and compact
Quick release mount
Waterproof and very wide temperature operation range -20C to +50C
Designed for rifles that generate 6000 Joules ME, such as .375 H&H Mag
Converts into a 10x Hand-Held Digital NV Monocular with an optional Pulsar 10x32 daylight monocular.
The Forward DFA fits on to the front optical bell of a day telescopic sight using a specially designed mounting assembly. These assemblies are available in various diameters and each has a set of reducing rings (the rings can be used as necessary depending on the diameter of the optical bell) for a precise fit. The adapter is permanently attached to the optical bell of a telescopic sight, enabling the Forward DFA attachment to be quickly
installed when required. When the attachment is not used, the adapter accommodates a protective cap that covers the lens of an optical sight in the daytime.
The Pulsar Forward DFA75 will fit most scopes between 40mm and 56mm, using the correct adaptor ring.
