Camera is a splatty cam with digi zoom and auto zoom if selected and pan and tilt very easy reticle build with this menu,No loss of zero on zoom like a first focal plane scope image and ret increase in size together
30mm cs extension tube for main body and cs to 42 mm adapter with auto chinnon F1.17 lens scope mount/ rifle mount is weaver base with weaver top to ring, supplied will be 9/11 dovetail to weaver adapter.
Main tube has wind and ele turrets to allow near enough zero with privacy for fine zero
Viewer is vf2 color high def, supplied by splatty to me with switch and ir cut removed
Osd and vf2 controls are accessed through ports in top of electronic box with covers.
Power is via elwire 1800 mah flat battery pack with charge protection and charger
If you wish the m42 and adapter can be removed and a cs lens of your choice be fitted in its place ,
I can supply an super palar auto 135mm f 1:2.8 which gives approx 12x instead of the 55mm or both for extra £15
I am asking £250.00 both lenses £235 one lens plus £6.00 pos
