some bloke M42 to E700 adaptor
I'm a newbie so this is partly for newbies and because Dave asked me to warts and all - sort of.
In deference to some bloke, just a few comments about the some bloke M42 to E700 Delrin adaptor and handle he has developed and keeps in stock and actually had the audacity to charge me for. Well I can tell you that it appears to work, is well machined to very close tolerances with room for small modifications if one so wishes. ATMIT i am very pleased with the purchase and am surprised at just how light the combination is. Next job is to get the E700 body machined to my spec and to 'permanently affix' to the adaptor. My main concern will be to get the distance between focal planes 'right' at this juncture and there is info on here somewhere to help. It would be nice to have some sort of reference 'polar diagram' as to the likely mechanics and angles of light coming out of the lens and being projected onto the sensor - so cutting the neck back on the camera body and tapering the thread back on the inside will have to do - hope so. Have also purchased a suitable 50mm 1.8 Pentax lens as per SB's implore and the screw fit lens fits the adaptor like a glove and jury rigged the on screen image from the setup is looking good. Night time will tell. Keep you posted.
- some bloke
- NON EMMET
Re: some bloke M42 to E700 adaptor
Hey thanks for that my 'ansum.
The adaptor was made so the required focal length (which is very tolerant unless you need to take portrait photo's) will be achieved when you insert the neck of the E700 into the rear of the adaptor until it stops. As the square body engages the rear neck of the adaptor it becomes square as if by magic.
The ability of silicone sealant or hot melt glue to flow around the edges of the very lightweight E700 metal body without having to fit any other anchorages is very simple and effective. As the E700 neck is a slightly snug friction fit into the adaptor think of it as a press and go but you could maybe squeeze a length of 1" angle iron into your box to locate it if looking for a more involved and time consuming locating method.
Re: some bloke M42 to E700 adaptor for newbies
Managed to turn the little camera body on a rough jig after hack sawing several mm off the length. So faced the square outer face a tiny bit (which it really didn't need as it was pretty square to start with) and turned a tiny register on the taper next to the body/face and it held (in a four jaw) so got lucky there and then tapered off the inner threaded bit. I don't think that stuff is ally - more like mazak but it is deceptively strong and it will tear a bit unless your tool is sharp. Just to say to anyone attempting this for the first time you do not have to go these lengths (in fact don't bother) to get the body to fit the adapter. In fact I now have five thou of play between the register and the adaptor and had I left the E700 body alone in the first place (just shortened it neatly I could have made up some spacers, achieved the desired effect and saved myself a load of work, however now I know why these guys just use a file. In fact truth be known I still don't know what I'm doing but its a lorra fun and it ain't broke yet! There is nothing complicated about a build because an awful lot of these NV guy have done it all before and the adaptor does the rest for you. i have to say that without the adaptor I would not have bothered - just too much work.
- some bloke
- NON EMMET
You have some good materials knowledge there Alf - I assumed it was ally. I had to google mazak die casting to discover more about it.pickle wrote:Managed to turn the little camera body on a rough jig after hack sawing several mm off the length. So faced the square outer face a tiny bit (which it really didn't need as it was pretty square to start with) and turned a tiny register on the taper next to the body/face and it held (in a four jaw) so got lucky there and then tapered off the inner threaded bit. I don't think that stuff is ally - more like mazak but it is deceptively strong and it will tear a bit unless your tool is sharp. Just to say to anyone attempting this for the first time you do not have to go these lengths (in fact don't bother) to get the body to fit the adapter. In fact I now have five thou of play between the register and the adaptor and had I left the E700 body alone in the first place (just shortened it neatly I could have made up some spacers, achieved the desired effect and saved myself a load of work, however now I know why these guys just use a file. In fact truth be known I still don't know what I'm doing but its a lorra fun and it ain't broke yet! There is nothing complicated about a build because an awful lot of these NV guy have done it all before and the adaptor does the rest for you. i have to say that without the adaptor I would not have bothered - just too much work.
I just push the E700 body firmly into the adaptor neck to get it to self align on the shoulder as it pinches up to a friction fit that retains itself for gluing purposes.
I could ease out the neck I/D for people who would rather a slide fit and put a weight on it or clamp it into position while the adhesive sets.
Looking forwards to seeing the end result now.
Dave i have a problem here as I keep losing my post b4 I upload it so you guys can see it. Come back to you.
Hi Dave just tried to save a draft for you but something is shutting me out and I lost it. Never mind.
Looks like it could be this old mechanical keyboard - shame.
Hi SB, I seem to have a problem with the SLR lens on the adapter. The E700 camera is taped on to the adaptor for now and won't move. The lens focuses in daylight and quite likes the horizon this evening but will not produce a decent image on the monitor in the mid-ground. The image is very fogged and there seems to be an awful flare apparent. The Pentacon 1.8 lens has a multi coating but i do not know what to make of the fog. I believe the E700 sensor is the right sort of distance from the SLR lens, E700 body square and have swapped monitors to no avail. The monitor shows a 'cameraid' logo on top of screen when fired up and does not go away. Any ideas as am stumped.
- some bloke
- NON EMMET
Hmm that's stumped me Alf. You spoke of tapering the inside of the neck - I'm wondering if that might be allowing light to bounce off the taper if its a smooth finish. Try painting it matt black if you can.pickle wrote:Hi SB, I seem to have a problem with the SLR lens on the adapter. The E700 camera is taped on to the adaptor for now and won't move. The lens focuses in daylight and quite likes the horizon this evening but will not produce a decent image on the monitor in the mid-ground. The image is very fogged and there seems to be an awful flare apparent. The Pentacon 1.8 lens has a multi coating but i do not know what to make of the fog. I believe the E700 sensor is the right sort of distance from the SLR lens, E700 body square and have swapped monitors to no avail. The monitor shows a 'cameraid' logo on top of screen when fired up and does not go away. Any ideas as am stumped.
Does it focus at infinity and close up - and how thick are the spacers you fitted - presumably between the adaptor and the camera body?
Never heard of cameraid - could it be camera id? that is a feature where you can input the name of the camera but I've never done it myself. It might be wise to reset the camera.
Yes I did reset the E700 and camera id it went away. Have a slightly better image now but still not as good as the board lenses - still hazy. However you pre empted me there as I wondered about my super duper tapering and perhaps that may be part of a problem. Will try your suggestion.
Because I turned down the E body neck a touch I did not have to fit a spacer they just married with about 5 thou play between your ADR and the E neck - lovely fit and perfect for getting in a bit of adhesive or whatever. After a bit of thought my spacer idea might pose a problem as I forgot about the bit in between namely the plastic box. Yes it does focus at infinity and close up, however nowhere near the definition I get from a board lens. I wondered if it was because I bought a cheap 1.8 Multi Coating Pentacon lens and the coating might just be the problem.
It could only happen to me. I wonder how other forum members get on with their M42 builds - no one seems to have commented yet. Someone must have an angle?
- some bloke
- NON EMMET
I find the multi coated lens gives a perfect focus - and is marginally less focus fussy than the F1.4 C mount lenses.
I'll go see if I can find any videos I have done with one fitted.
EDIT: I can't find any I made with an M42 lens and an E700 camera - sorry.
