Wanted Sunshade for Optisan MTC Mamba/Viper 4-16 x50
On the off chance somebody may have one of the above laying in their spares box.
Thanks for looking.
Thanks for looking.
Re: Wanted Sunshade for Optisan MTC Mamba/Viper 4-16 x50
Hi Blueroll,
From what I can gather the size for the the outside thread is between 54mm and 55mm I purchased one which is 56mm but it is to big.
Because it is a older scope it appears to be discontinued according to Ants web page.
Regards
Paul
Regards
Paul
I will measure it and get back to you.
I forgot that my Lad has it for use with his Hawke, but may not need it now that he has an SRX illuminator.
However I do have 3 Swaro sunshades and they measure 54.69mm diameter across the exterior threads.
Hi Blueroll,
No probs I may be able to get someone to re thread the 56mm shade down for me.As far as I can gather it is a gamma shade which is no longer in production.I measured the pop up ring and that appeared to be 56mm but that is obviously the outer edge as they are tapered to fit.
Regards
Paul
Regards
Paul
Have you tried Ant Supplies, they used to have lots of sunshades ?skewey wrote: ↑08 Apr 2019, 19:05Hi Blueroll,
Regards
Paul
Yes I have checked their web pageand have also text them on the off chance
InTheSticks
I have a brand new one that is off a Optisan 6-24 x 50F1 I don't know if the thread is the same ?
I have an old mtc scope and it has a sunshade.Not sure what model it is but I will check on Monday when I am home
