Pard Bargains
Mini Magnum
Pard Bargains
Post by Mini Magnum » 01 Jan 2020, 11:15
I have available a few brand new Pard units with minor defects for a lower price. They all work perfectly and are new.
Pard NV019 spotters, dust speck on screen, either live with it or open to remove it although you will void warranty. £119.99 each delivered.
Pard NV007 16mm units with IR slightly off centre, only noticeable on full spot possibly, if using an external illuminator wouldn't matter regardless, same again can be re-centered but you will void warranty, £299.99 delivered
Pard NV007 slight blemish on external glass lens of vscel or minor mark on external case like a 1mm mark, absolutely nothing in all honesty. £319.99 delivered
Pard NV008 with IR slightly off centre, only noticeable on full spot possibly, if using an external illuminator wouldn't matter regardless, same again could be re-centered but you will void warranty, £449.99 delivered
Pard NV008 LRF with IR slightly off centre, only noticeable on full spot possibly, if using an external illuminator wouldn't matter regardless, same again could be re-centered but you will void warranty, £649.99 delivered
Very limited quantity..
wall90
Re: Pard Bargains
Post by wall90 » 02 Jan 2020, 06:44
hi ian, would the pard 008 still be covered by warranty apart from the laser?, and would the laser still give enough illumination for 22 rimfire ranges when not on spot,thanks alan
Mini Magnum
Re: Pard Bargains
Post by Mini Magnum » 02 Jan 2020, 09:31
Yes you probably wouldn’t notice anyway.
pav
Re: Pard Bargains
Post by pav » 02 Jan 2020, 11:27
Iv looked through one at ians and I think he knit picking pull ir all way out and just push it back a fraction and you would tell from any other
master tech
Re: Pard Bargains
Post by master tech » 02 Jan 2020, 12:28
Hi mini magnum
I will take a 007 16mm please, PM me and we will sort out the payment.
Regards, Mastertech.
Mini Magnum
Re: Pard Bargains
Post by Mini Magnum » 02 Jan 2020, 15:59
master tech wrote:
02 Jan 2020, 12:28
Hi mini magnum
No problem
Just message me your details, email, number and address and I will send a payment link.
Bank Transfer
Card
Paypal
Whatever suits.
wall90
Re: Pard Bargains
Post by wall90 » 02 Jan 2020, 16:39
in that case ian I will have a pard 008 if there is still one available,i will pm you my details and I will do bt if you send me your info.thanks alan
master tech
Re: Pard Bargains
Post by master tech » 02 Jan 2020, 20:29
Hi Mini Magnum
I cant seem to get a PM sent at present, could i e mail you?
Regards, Master tech.
Mini Magnum
Re: Pard Bargains
Post by Mini Magnum » 27 Jan 2020, 10:19
More NV007 and NV008 LRF units available as above.
anthony
Re: Pard Bargains
Post by anthony » 27 Jan 2020, 12:59
Hi ian mate of mine is interested in the nv019 but whereabouts is the speck dust on the screen?
Theoben Rapid 7 Mk2 fac 30ftps 3-9x50 AG + AWT Silencer PVS14
Theoben Rapid 7 Mk1 + AWT Silencer NV007
Ruger 10-22 / Tasco 3-9x50 AG + NV008
CZ 17 HMR / Tasco 3-9x50 AG + NV008
223 Howa 1500 Laminated Thumbhole Stock + WT1 75-3
