olson black wanted *SORTED*
hi is there anyone out there who can make me a p60 dropin fitted with an olson black ir please
- some bloke
- NON EMMET
Re: olson black
thanks for that (bit slow me eh!!!
- some bloke
- NON EMMET
Re: olson black
I forgot to tell you to let him know which battery you use, and ask for the reflector to be left loose so you can black and focus it.
Re: olson black
THANKS FOR THAT ORDERED TODAY CHEERS JEFF.
Re: olson black
how much does the end cap need moving to gain focus? is it the 4mm as ive heard about before?some bloke wrote:I forgot to tell you to let him know which battery you use, and ask for the reflector to be left loose so you can black and focus it.
- some bloke
- NON EMMET
Re: olson black
You can only usually get maybe 2mm~3mm adjustment with the standard lens.
I prefer to have mine slightly out of focus towards the LED but the reflector shape won't allow any more light to be picked up by making it closer because it obstructs the outer portions of the LED half angle.
