Hi All
I'm finding it difficult to locate new, thats not over the top in price and size wise so I'm
Looking for a small hard case for bull pup (fx wildcat size 90ish cm long x 30ish cm wide) no need for it tobe bomb proof Nuprol type will do, let me know whats out there.
. . Cheers
Hard rifle case wanted
Re: Hard rifle case wanted
I've used 2 of these for about 10 years, sold as Airsoft cases (although these at Countryman look identical rebranded versions - https://www.thecountryman.com/countryma ... rifle-case) - wouldn't chuck them on an airplane (they're just hard plastic with a foam lining), but countless rifles with nv/thermal scopes have survived being chucked in the back of the land rover (and dropped a few times) without a problem. The larger one will fit a Blaser with DPT mod and thermal scope ready to shoot. Depending on scopes and barrel lengths etc you can squeeze two in the larger version. The smaller one is about the size you want I guess;
Larger: https://www.factorycases.co.uk/evolutio ... 2?pv=41420
Smaller: https://www.factorycases.co.uk/evolutio ... 5?pv=41425
Not bad for 60-70 quid, I lost one (literally no idea where it is, you'd have thought quite hard to lose ;p) and bought another one a few weeks ago off Amazon ('cause Prime).
Thanks for the info they look just right, if no one else has one l shall go that way
thanks
thanks
