Magnetic Truck mounted Thermal Spotter/Finder
Post by some bloke » 31 Jul 2025, 15:36
I made this item with loads of guidance from a very helpful Phoenix on here.
Let me be very clear - the thermal specification is quite old and not as good as found in more recent or expensive thermals available.... which is why I call it thermal spotter/quarry finder. It'll find something warm that warrants steering a shooting truck towards: such as Rabbits at 200 yards, adult Fox size at 350 yards or Deer at 500+ and safety wise an adult human. It'll save holding a hand held monocular out the window of a truck and its not waterproof.
The imaging signal is not wifi with the accompanied lag - its the same no-lag radio frequency system that is used for flying FPV Drones. I mount the magnetic camera unit just in front of my sunroof but it can be used near a window or a roof rack for the driver or gate bitch to reach out and manually pan and tilt. It has a plain rear cover (seen under the spare batteries in the photo) or a 5" screen that allows it to be used by hand too - unplug it to avoid draining the battery or being seen from behind the truck when not needed. There is no cabling needed to power it nor to connect to the 7" monitor inside the truck.
The 7" monitor's internal battery failed: so I've silicone rubber glued 18650 battery holders onto the rear, and incude 6 spares. The battery holders can be cut off if the buyer elects to use a 12 volts cigar lighter socket. It has a record feature but note the radio signal transmission is effectively white noise so there is a radio chatter and occasional intereference to be seen and heard, probably from low altitude aircraft approaching EMAP on any videos made.
Feel free to come to East Leicester for a demo - I won't be offended if you compare the image to better thermals and decline to buy it.
£750 collect only so you see what you are getting and how to use it... Also advertised elsewhere. Please PM me if you have replied.
Here is a very quick demo video of the unit. https://www.youtube.com/watch?v=sNWJ1UzZq_4
Re: Magnetic Truck mounted Thermal Spotter/Finder
Post by some bloke » 08 Sep 2025, 11:28
Reduced to £600 as my FAC surrender draws nearer.
I ought to point out that there are three signal transmission range/power settings in the base/camera sender unit: 600mw for very long distance image transmission, 200mw for moderate image ranges and 25mw for very close range when other users won't be using the same frequency.
I set it at the lowest as I only need to send the image two meters or so to the 7" monitor near my gear stick. The occasional interference spike makes no difference for my in car observation or detection of a heat source location.
A person easily annoyed about the spikes can increase the transmitting power but be advised it will consume more battery power for no quarry finding gain: you will get better quarry detail as you get nearer and you won't get the poke in the eye feeling while doing it like you get from holding a monocular up to your eye.
How to change the power setting is here: https://www.youtube.com/watch?v=8EWvUZyztKU
