They will be offered with various diameter 'iris' holes so as to not restrict too much light, relative to the illumination amount that is being used.
People using moderate IR levels, or shooting at outer rimfire ranges will probably find a 25/26mm ish diameter fixed 'iris' is an ideal size to allow sufficient light passage to the sensor.
Anyone using more a more powerful illuminator than needed - who perhaps don't have light shy quarry, or uses the Photon at very close range might benefit from a smaller diameter 'iris'
Sizes are yet to be finalised with trials and I reserve the right revise sizes as I see fit. It will be a good idea if you state the range you are shooting at - and what IR you are using when ordering.
These require a much more decisive action to remove them than the supplied daytime iris lens cap which can easily get knocked off - the fit is very good:
http://youtu.be/YgiDHbDeglc
There is a recess in the front of the cap to allow anyone to glue an IR pass filter to the cap if they wish, the filter size needed is 52mm, remove the glass from the threaded carrier and glue it into the recess. I used super glue for these but black silicone rubber is probably better.
For those who have not seen the difference this can make, take a look at this video;
http://www.youtube.com/watch?v=4F-BxiP6 ... e=youtu.be
The bulk of the focal improvement was a result of using a reduced light intake via the 'iris' hole. Fitting the filter gives the image quality a slight boost at night, I have not yet tried that in daylight, but the standard lens cap with an even smaller iris and neutral density filter is supplied for that purpose.
I recycle packaging.
Whilst my 501b sales have usually been done via Private messaging, details of this item cannot be viably shown or addressed with my signature picture, so for the first time - I'll be using this section for the lens cap sales. Please make any enquiries on this thread rather than Private Message because I have to frequently delete them and lose track of who has what.
PayPal addy is: davidgeorge69@btinternet.com
Please put your forum name and delivery addy, and what the payment is for in the paypal notes box.
