Home Brew number " 2"
techno
Post by techno » 17 Mar 2014, 18:37
Home brew 2 is up for sale
it comprises of
An ej230 bullet cam £95
Billet Ally mount made to fit 30mm mounts £100
hd screen 120mm x75mm £15
edmund optics lens adaptor c to cs £50
6-60 stock optics zoom IR spec lense £60
Ultrafire 501b torch with a some bloke IR pill, ahorton lens and spacer £50
various bars bolts and mounts ,cables plugs and sockets £20
Ive started the MK3 and could do with some dosh to complete.As is this is suitable for std air rifle ranges, you can mod it further by changing the lense, it was born from Rolaids Videos.As its made from bits you can carry on further with it, but im now building a mahoosive one.
The camera body is inside the billet ally tube,and you adjust the zero by moving 8 grub screws back and forth,My next unit will use springs to hold the camera body and move back and forth via the grub screws and springs.You put your finger inside the ally tube,to adjust the cam without removal, the screen is detatchable and it has video out.
You'll need a 12 volt battery for the setup, and a 18650 battery and charger for the torch.
The rings where the 30mm scope mounts go are 24mm wide and the gap between the two mounts is 60mm, the torch is mounted via a proper mount now not a cable tie.If you want to zip it up for rimfire ranges you need a bigger badder lense say 100mm, this is fine for sub 12ftlb,its so dark the bunnies cant see you anyways.
IT should all plug and play and i'll test before dispatch.Looking for £295 posted rmsd
