25mm CS lens and board adaptor - Wanted -
- AirRifleSport
As per subject.
Thanks.
Thanks.
- 22-250jock
Re: 25mm CS board camera and board camera adaptor - Wanted -
franco
do you mean a 25mm cs lens and board adaptor?
cheers john
cheers john
- AirRifleSport
Re: 25mm CS lens and board adaptor - Wanted -
Hi John,
Thanks for noting that...
Yes mate.
I did update the subject. Thinking of using this for a spotter.
Franco
Franco
Like these?
http://www.ebay.co.uk/itm/5xPCS-New-CCT ... 4d10762fa7
Got the same problem so ordered last week..... slow boat syndrome!
Bif
Bif
- AirRifleSport
That should be the one but I am also looking for a 25mm IR sensitive lens.
25mm would be too much of a wide angle fov for spotter franco, I used one earlier, the ir torch would cover 30 yards max, after that its all grainy. You are better of with at least 50mm.
I have a 25mm if you want to play with. Send me your addy, ill post it tomorrow.
Toni
Toni
- AirRifleSport
Hi Toni,
Thanks for that. I have been considering doing a little experiment...
Don't laugh... I have a feeling that I could use the doubler used on the T20 to magnify the focal length of a 25mm lens. This does work to some extent with the 16mm lens. Maybe you could try it for me, if you do have the doubler that is.
I have the lens bug at the moment, bought so many in last few weeks, been experimenting myself too.
The doubler is no good, day time is ok but at night you loose so much clarity is unblevable. When I got my scopeless at first, I had only a 16mm and 25mm cs lens, thought the same, used a doubler and I was well disappointed.
Toni
Toni
- AirRifleSport
Fair enough, I am glad you came to the rescue mate, you saved me some money. What would you recommend I use, keep in mind that it is for spotting at the moment as I do not want to remove my existing scope off the rifle.
I am going to go out now so I will reply to your next message when I am back.
Cheers, Franco
Cheers, Franco
