Wanted - 2x 12v T20's for spotter build.
AirGunJord
Post by AirGunJord » 09 Jun 2014, 09:49
In need of a couple of 12v T20's to be used on a vehicle spotter. Plan is to mount them side by side of a 100mm stock optics lens and EJ230 for extreme spotting rage. Will be using a high mah battery with charging port for use with 12v car charger.
davyo
Re: Wanted - 2x 12v T20's for spotter build.
Post by davyo » 10 Jun 2014, 15:42
I wired 2x t20 ir's using 12v-3.7v restrictors, E700 board cam plus 7inch monitor,all pwered off the accessories socket.Have the EJ230 on the rimmy.
weebster
Post by weebster » 10 Jun 2014, 20:32
Drop sikastag a pm or email,he should be able to sort you out. :thumbup:
