spotter/ rifle nvrs digi and ir torch PRICE CHANGE
genisis22
Post by genisis22 » 30 Jul 2014, 15:04
Hi Guys, here is a spotter that I made up with sony effio e cam 1/3 sensor nxt gen chip very good in dark ,Ir cut removed, on board quality 1800 mah battery comes with 1 amp 12 v charger, charging port, and good crt near eye display/viewer osd menu easy accesable all protected against over under charge etc, with a auto chinnon 55 mm lens @F1.17 manual focus and iris, has a weaver mount on base to weapon fit if prefered cross hair by privacy as usual
Image[/UR
Also T20 oslom ir torch with lens 2x double fitted and adapter you can use with or without 2x lens as range depicts, torch body has some mount marks and comes with high weaver mount [URL=http://s1167.photobucket.com/user/genis ... 4.jpg.html]Image
[url=http://s1167.photobucket.com/user/genis ... c.jpg.html][img]http://i1167.photobucket.com/albums/q63 ... nvrs026_zp
£140.00 plus £6.00 post
