1 k pots for VF-c2 viewfinder ( brightness adjusting )
gypo
Re: 1 k pots for VF-c2 viewfinder ( brightness adjusting )
Post by gypo » 28 Feb 2015, 20:42
Ok cheers mate.
G
gypo
Post by gypo » 04 Mar 2015, 16:26
Received today mate thanks.
Which connections do I use?
G
CustomRifleScopesUK
Post by CustomRifleScopesUK » 04 Mar 2015, 18:25
Glad you got it mate.
I did put a small wiring diagram on the first page....can you not see it ?
Splatty
gypo
Post by gypo » 04 Mar 2015, 18:33
Yes sorry mate, was sending via phone and forgot you did that :thumbup:
G
demonfox1
Post by demonfox1 » 07 Mar 2015, 02:46
Hi splatty can these pots be used on crt viewer from a camcorder
Gary
CustomRifleScopesUK
Post by CustomRifleScopesUK » 07 Mar 2015, 07:55
demonfox1 wrote:Hi splatty can these pots be used on crt viewer from a camcorder
Gary
Check the voltage and resistance first. But usually if under 5v it would be fine, you won't damage it by resisting voltage with a 1k pot just to test it. It would be like your batteries running low on your camcorder !
Remember though to connect to the back light of the screen only. The power that runs the crt light and not the crt itself
Hope this helps
demonfox1
Post by demonfox1 » 07 Mar 2015, 08:09
Thank you for the reply splatty very helpful :thumbup:
Gary
BT65
Post by BT65 » 07 Mar 2015, 10:28
Are these pots linear, or log, please splatty?
CustomRifleScopesUK
Post by CustomRifleScopesUK » 07 Mar 2015, 11:12
BT65 wrote:Are these pots linear, or log, please splatty?
I don't think log would work on the viewfinder but don't quote me on it, these are linear !
gypo
Post by gypo » 08 Mar 2015, 16:24
Splatty where can I get the knobs to fit on the dimmer switches from mate?
G
