Forum screen size
Ranger22
Re: Forum screen size
Post by Ranger22 » 03 Mar 2013, 07:35
To wide for my screen too
Al
ratz1
Post by ratz1 » 03 Mar 2013, 09:05
the pictures fit but some lines of text are too long, not oftern's tho.
ratz1
anthony
Post by anthony » 03 Mar 2013, 10:27
i had the same problem all i did was change the monitor setting to 1280x1024
CZ 17 HMR / Tasco 3-9x50 AG
SikaStag
Post by SikaStag » 03 Mar 2013, 11:30
Everything is hunky dory for me. Same as when I first joined.
Ian
silent shooter
FOUNDER
Post by silent shooter » 03 Mar 2013, 16:17
Hi all
I have spoken to John (sirhank) he says its very unlikely it is anything to do with the statistics box as it was made the correct width and height for the space,also the program we use is designed for universal width and not variable
He suggests checking your displays on your laptops etc to make sure you are using the correct display settings,he is going to investigate further but for now i hope this helps some of you.
Geoff
Post by phoenix » 03 Mar 2013, 17:59
anthony wrote:i had the same problem all i did was change the monitor setting to 1280x1024
My monitor is also set for 1280 x 1024 but I still have to scroll to see the full screen. My monitor is the old 4:3 format and wondered if the people using wide screen monitors - 16:9 format were having the same problems.
Post by phoenix » 03 Mar 2013, 18:02
Could this be anything to do with the monitor format.
I'm using a 4:3 (non widescreen ) monitor set to 1280 x 1024 but still have to scroll to the full contents of a page.
I wondered if people with widescreen monitors - 16:9 were having the same problem
rodp
Post by rodp » 03 Mar 2013, 18:32
It can't be a monitor problem as it's as it's always been, the monitor has not altered. It suddenly happened a few days ago after we had a spate of large pics (if I remember correctly)
If I alter the monitor to try and get it all on then the text becomes so small it's unreadable :crazy:
Marky610
Post by Marky610 » 03 Mar 2013, 18:42
I have wide screen at home and old 4:3 at work, both work fine.
fizzbangwhallop
Opening links in a new window?
Post by fizzbangwhallop » 03 Mar 2013, 19:41
I don't have a problem with screen widths on my Mac and Nexus 7's but whilst we're on the subject... am I missing a setting to open links in a new window?
It does this ok on other forums I'm on but not on here... and sometimes I get lost!
atb
ps Could we have a sunrise and sunset times box up in the banner as per the moonphases one - very useful that.
