HMM, I'm going to have to say I don't know TBH. I don't have a doubler to try it on, and don't anticipate getting one. I've seen somewhere, on here I think, that the doubler has a flip up lens cover on it - with a 15mm (IIRC) iris hole in it? Well it would be a hole if you push out the filter in it apparently.garyw wrote:have you one that will work with a doubler ?
Photon Lens caps with 'iris' @ £24
- some bloke
- NON EMMET
Re: Photon Lens caps with 'iris'
would be worth trying i suppose.some bloke wrote:HMM, I'm going to have to say I don't know TBH. I don't have a doubler to try it on, and don't anticipate getting one. I've seen somewhere, on here I think, that the doubler has a flip up lens cover on it - with a 15mm (IIRC) iris hole in it? Well it would be a hole if you push out the filter in it apparently.garyw wrote:have you one that will work with a doubler ?
atb
Springer
There is nothing complicated about this, cut out some circles from card which will fit just inside your lens, then cut out different sized holes in the middle and give them a try, 20mm is a good place to start. As Dave has also said, pop out the filter in your lens cover, the hole is smaller but again it will work.
Creating a smaller aperture works exactly the same on a doubler as it would on any other lens.
- some bloke
- NON EMMET
Original post is updated now with revisions to the product and price. They are now available.
cheers-after some blokes post i searched on the general night vision section and read the posts you put up about the reduced lenses it all makes sense to me nowSpringer wrote:There is nothing complicated about this, cut out some circles from card which will fit just inside your lens, then cut out different sized holes in the middle and give them a try, 20mm is a good place to start. As Dave has also said, pop out the filter in your lens cover, the hole is smaller but again it will work.
thanks for the reply anyway.
package arrived safely...with thanks
- some bloke
- NON EMMET
All PM's replied to - yes they are in stock now thanks.
- some bloke
- NON EMMET
Edits and more information added.
Hi Dave
Do you have the iris lens cap in stock for a standard photon using your 501b ir for shooting at air rifle range?
I also want a 501b tail cap switch. What's the the total price posted?
regards
Mark
regards
Mark
- some bloke
- NON EMMET
Both in stock Mark, thanks, £38 posted RMSD please mate.Kgbmark wrote:Hi Dave
regards
Mark
