What magnification do you use ? Not NV.
FGYT
Re: What magnification do you use ? Not NV.
Post by FGYT » 30 Aug 2012, 12:02
10 to 50 x 56 with mil dot for 177 cal
use it on 10 x for ratting and scanning or quick shots and 50 mag for long range checking out the next field shooting at over 25yrds / sniping
never use the in between mags just 10 or 50
using teh Mil dot with 177 at 12ft lbs the trajectory matches the mil dots very will at 50 x and scales at 10 ie 5 spaces and 1/5th the mag
or 177 i find at 10 mag 8yrds is 1 dot down
cross hair is 12yrds and 40 yrds
and 1 dot down is 55yrds
so for FT ever thing fits 2 dot spaces
Scope only has the std mil dot ret the extra lines just show the range to the dot and the mid point between dots ( as its easy to guess 1/2 way)
if i zoom in to 50 mag
its like this
heres a std 40mm FT kill zone ar 30 yrds on 10 x and on 50 x ( did this years ago before there where camera mounts so its just holding the camera giving a poor image)
i prefer aiming at a large dinner plate ;)
Image Image
Dorset Woodland Blades: 'I see you've played Knifey Spoony Before'
Gloop
Post by Gloop » 30 Aug 2012, 12:12
Crikey, thats a lot of dots. I would never remember all the drops. mainly I suppose cos a have more than one rifle to use.
