Clearing out some stuff that I no longer need use or have purchased and not used,
******* Barr and Stroud Sahara 7x42 binoculars good condition with case and neck strap,
£55 posted,I may have the box but can't find it as yet, very good glass on these and have served me well when out stalking,(sorry no box)(SWAPPED WITH ALAN/CONEY FOR A L808 )*******
2. Brady shotgun slip far left number 1, early one with strap internal size 41" leather and canvas, no rips or holes just a classic side by side slip
Will be looking for £45 posted
3. Brady shotgun slip centre number 2, early one again but with no shoulder strap size is longer 42" side by side,
Will be looking for £45 posted,
4, Brady slip as above with leather and canvas, strap, no holes or rips, this one is for a short over and under 41" long
5. Reeding 20 tactical full body die, used but in nice condition,
Looking for £55 posted this is as low as I go, fully boxed with instruction sheet.
6.new with tags on pair of mole skin trousers 40 waste but a tight 40 so could be a 38 tried on but I'm a fat burger, they have a non tailored leg so are about 36" long in the leg and will need tailoring, turned up, etc £30 posted, photos to come
7. a selection of bolt knob balls (golf ball is there to show the size I have forgotten the thread size in side,
£10 each posted or all 4 posted for £35.
8. QB78 wood stock, not bad condition but no longer needed.in used condition and has a few marks here and there but nothing to bad. serial number plate on the butt plate.
£20 posted
******** this is a trace handheld lamp with a light force 140 cone, home made shroud, no plug on the end but I can put on what you chose from crocodile clips or a cigar plug, new 12 volt 75 watt lamp fitted
£45 posted(SWAPPED WITH ALAN/CONEY FOR A L808) WILL FOR CROCADILE CLAMPS ON IT FOR YOU, bob.********
I will add more bits to clear out the work space known as the dog house, Hope this is ok with the moderators team and other members
cheers
PS: I AM LOOKING FOR A T20 IR 3 MODE WITH RATS TAIL, so if any of these interest you we could do a swap.
I WILL DO A MULTI SWAP OF THE KIT THATS LEFT FOR A HAND HELD SPOTTER WITH AS MUCH OF THIS KIT AS NEEDS BE.
Small clear out
Small clear out
Re: Small clear out
What type of burger would you describe your self as
Re: Small clear out
just a fat juicy burger with double cheese lettuce and sauce onthesmi wrote:What type of burger would you describe your self as
bob,
Re: Small clear out
Sounds tastey. I'd describe mine as a triple whopper with jalepinos
Re: Small clear out
all prices dropped by £5
thank you
bob.
thank you
bob.
Re: Small clear out
bolt knobs,
http://i28.photobucket.com/albums/c238/ ... 4zjn9p.jpg
£20 the lot posted
qb stock
http://i28.photobucket.com/albums/c238/ ... 4vccxu.jpg
£20 posted
shotgun slips.
£100 all three posted
20 tac body die
http://i28.photobucket.com/albums/c238/ ... bjvibd.jpg
now just £50 posted
thanks
bob.
£20 the lot posted
qb stock
£20 posted
shotgun slips.
20 tac body die
now just £50 posted
thanks
bob.
