Slimline 11mm Dovetail to Weaver Rail Mount (Ideal for NV)
KRW
Post by KRW » 14 Oct 2012, 10:24
Umarex Dovetail to Weaver Mount
Unused, removed from packet to photograph.
Low level slimline mount rather that the higher and bulkier ones that are generally available.
These slip straight onto the HW100 breech and are a very good push fit secured in place with two small grub screws on the top face, also fit straight onto the Crosman steel breech but I have fitted them to other rifles with slightly narrower 11mm dovetail rails and they needed a little fettling to the rail with a smooth file to fit.
Can now swap from day scopes with QD weaver rings to NV on all my set ups without loosing zero.
I have a couple of these surplus to requirements
£35 posted
Umarex 850 Rail 2.JPG (129.02 KiB) Viewed 2886 times
silent shooter
FOUNDER
Re: Slimline 11mm Dovetail to Weaver Rail Mount (Ideal for N
Post by silent shooter » 14 Oct 2012, 12:35
Welcome to the forum KRW :wave:
KRW
Post by KRW » 14 Oct 2012, 12:58
silent shooter wrote:Welcome to the forum KRW :wave:
many thanks :thumbup:
