gypo
Post
by gypo » 20 Nov 2016, 12:07
As per the title gents
I've got a spare one of these kicking about, I was going to hang on to it but it's not getting used.
£160 posted.
Please reply here not pm as my notifications are still not working.
G
image hosting site over 5mb
gypo
Post
by gypo » 25 Nov 2016, 07:23
Bump this
G
beakie74
Post
by beakie74 » 03 Dec 2016, 16:14
What mag would this give ?
gypo
Post
by gypo » 04 Dec 2016, 10:35
Not sure but I'm sure someone will be along soon who can answer it, I'd guess at about x10.
G
- BRUCE ALMIGHTY
Post
by phoenix » 04 Dec 2016, 11:42
The magnification depends on the focal length of the lens and size of the sensor in the camera you use
For an E700 with a 1/3 sensor, the magnification would be approx x11
beakie74
Post
by beakie74 » 04 Dec 2016, 13:13
phoenix wrote:The magnification depends on the focal length of the lens and size of the sensor in the camera you use
Ah I should of said it was for a 6.5 photon extreme.
beakie74
Post
by beakie74 » 04 Dec 2016, 13:17
[quote="gypo"]Not sure but I'm sure someone will be along soon who can answer it, I'd guess at about x10.
G[/quote
I assume it's a M42 tread ?
Would you take £110 for it (posted, uk)
- BRUCE ALMIGHTY
Post
by phoenix » 04 Dec 2016, 13:20
beakie74 wrote:phoenix wrote:The magnification depends on the focal length of the lens and size of the sensor in the camera you use
The sensor in the Photon is 1/4 which would bump the magnification up to around x15
Radagast
- junior librarian
Post
by Radagast » 04 Dec 2016, 13:21
It's a heavy lens to be hanging off the plastic photon housing, 700 grams, or there abouts. IIRC, Gypo is the only guy running an Extreme with this lens, so he is your best source of advice.
Yes it is M42 mount.
FWIW I bought my 75mm Cosmicar from him and it was exactly as described.
beakie74
Post
by beakie74 » 04 Dec 2016, 13:37
Radagast wrote:It's a heavy lens to be hanging off the plastic photon housing, 700 grams, or there abouts. IIRC, Gypo is the only guy running an Extreme with this lens, so he is your best source of advice.
Would this be a better option Bruce ?
http://m.ebay.co.uk/itm/Cyclop-100mm-f2 ... Ciid%253A3
