hi lads n lasses
im selling senital scope ive had it since feb10 and funny enough still got the receipt to be honest its hardly been used still in the box with all the instructions £320 ono
heres the spec's
Image Tube Generation 1
Magnification, x 2.5
Lens Diameter, mm 50
Field of View, degree 13
Minimum Focusing Distance, m 5
Recognition Range, m 200
Eye Relief, mm 45
Exit Pupil, mm 6
Diopter Adjustment, D ±3
Resolution, lines/mm 35
IR Wavelength, nm 805
Power Supply, V 3 (2xAA)
Estimated battery life without IR under +20°C/68°F, hour 24/70
Operating Temperature, °C -30°C to +40°C/-22°F to + 104°F
Grade of water-resistance IPX4
Dimensions, mm 270x90x100
Weight, kg 1.0
atb gary
yukon sentinal nv scope
- Attachments
- garynobike.jpg (3.43 KiB) Viewed 6938 times
