FoxPro Prairie Blaster Electronic Game Caller With TX-500 Remote
mcroy313
Post by mcroy313 » 20 Jan 2022, 13:09
Have had this for a few years - it's in full working order and good condition, complete with the battery holder for D cells. (Note: i've always used a lead acid battery, 7.2V 3.4Ah, in lieu of the D cells. If the unit is collected F to F I'll happily include this battery - unable to post it though sorry!) - The rotating decoy is complete and fully working (wire & furry friend included in sale). The remote unit is the TX500. Will post some pics when I get home tonight....
Pretty sure that i've still got the instruction book for it but it's very simple to use.... There's over 100 different calls preloaded on to it also...
£110 Collected F to F from Wrexham - Now sold pending payment!
pb 2.jpg (14.65 KiB) Viewed 1510 times
Full spec is as follows;
Product Info for FoxPro Prairie Blaster Electronic Game Caller With TX-500 Remote Control System PB1
Blast away with FOXPRO's new Prairie Blaster! Combining the features of the FOXPRO Fury GX7 with a larger housing to accomodate four speakers and a decoy, the Prairie Blaster is an extremely versatile electronic game call system. The Prairie Blaster packs four speakers into one system. In the front of the unit is the popular SP-55 and a tweeter. In the rear is a large cone speaker and another tweeter. Together, these speakers produce incredible volume and amazing sound quality. The integrated decoy makes decoy use simple. With the push of a button, you can turn your decoy on or off. Carry less gear!
INTERNAL QUAD SPEAKERS: Two tweeters for high frequency sounds, an SP-55 horn speaker for intense volume, and a large cone speaker in the rear.
INTEGRATED DECOY: Can be controlled with the TX-500 remote with the push of a button. The Prairie Blaster comes standard with the "jack" topper.
The FOXPRO Prairie Blaster operates on 8 D Cell batteries, has 4GB of internal memory, stores up to 500 sounds, and has a USB port for programming sounds from home. The Prairie Blaster will play FXP, 24B, MP3, and WAV sounds. As with the FOXPRO Fury GX7, the Prairie Blaster featuers the most advanced remote control ever offered by FOXPRO, the TX-500. The large backlit LCD screen, numeric keypad, and rotary selector knob make navigation of your remote control very easy. The TX-500 utilizes FHSS technology for long range operation.
Features of FoxPro Prarie Blaster:
• 4GB Of Internal Storage store and play up to 500 sounds with the massive 4GB of internal memory! The Prairie Blaster will come standard with 100 high-quality sounds from FOXPRO's incredible sound library.
• 24-Bit Audio for extreme audio performance. The Prairie Blaster can play .mp3, uncompressed .wav, .fxp (FOXPRO's proprietary file type), and .24b (FOXPRO's 24-bit file type).
• Integrated Quad Speakers amplified SP-55 horn speaker and tweeter located in the front of the unit, large cone and a tweeter in the rear. Combined, they provide loud, crystal-clear audio and great frequency response. You can switch the internal speakers on/off from the main unit and from the TX-500 remote control.
• Integrated Decoy can be turned on or off from the TX-500 at the push of a button.
• Two External Speaker Jacks Connect up to two additional speakers to the Prairie Blaster for a total of four speakers playing simultaneously. You can control those external speakers from the TX-500 remote control.
• USB 2.0 Port quickly and easily reprogram your Prairie Blaster right from your computer!
• 16 Channels of Remote Operation - operate up to 16 different units from a single remote.
• Remote/Manual Operation - use the Prairie Blaster with the remote or choose to operate it manually from the controls located on the front.
• Stereo and mono operational modes can be selected from the TX-500 remote control.
• Red Backlit LCD Display
• Low Battery Indicator
• Battery Management System
• Operates on 8 'D' Batteries – I have the battery holder for this but I use a 7.2V 3.4Ah lead acid battery instead which I’ll supply with the unit. (Note: a charger is not included)
Features of FoxPro TX-500 Remote Control:
• Improved Remote Performance by utilizing FHSS technology, remote range and reliability will greatly increase.
• The extra large LCD panel provides easy to read text and menu navigation. The LCD panel features a red back light with adjustable brightness control (off, low, medium, high). You can also invert the graphics display for nighttime operation.
• Numeric Keypad Sound Entry. Don't like scrolling through your sounds? Directly enter the number of the sound you wish to play on the numeric keypad for direct access. For those that prefer the scrolling, the rotary selector knob allows you to scroll through sounds without the need for memorizing your sound list.
• Adjustable Sound Scrolling. Use the rotary knob to advance through sounds by the page (default) or by single sounds one at a time.
• 10 Custom Sound Presets Store. Up to 10 custom sound presets with individual volume levels. Two quick access preset buttons are located on the side of the TX-500.
• 10 Custom Sound Sequences. Design up to 10 entire stands including the individual sounds, volume levels, durations, and passages of silence. When selected, a custom sequence will go through the steps you defined and complete your entire calling sequence without requiring any need for using the remote control.
• FOXFADE - Manipulate the volume level of the L/R channels on a stereo audio file. For example, if you are playing a sound that has a rabbit on the left audio channel and a coyote on the right audio channel you can use FOXFADE to gain independent control of volume of both sounds within the stereo audio file (i.e. decrease the volume of the rabbit--or silence it completely--while the volume of the coyote remains the same or vice versa.) In mono operation, FOXFADE will act as a mixer moving sounds from the front speaker to rear speaker.
• A/V (Auto Volume). Auto Volume allows you to begin your sound playback at zero volume and slowly increase it to your desired level. Once your desired has been reached, the volume level will begin to modulate up and down. This leaves your hands free from making manual volume changes.
• Three Sound Playback Modes. Continuous Mode results in the selected sound playing continuously until you stop it.
• Single Play Mode allows you to have the selected sound play once, then stop.
• Sequential Mode will play one sound to the end then move on to the next sound.
• Adjustable Volume Ramping. Set the increment speed for volume increase and decrease. For example, you can assign each volume up/down button press the be equal to 2, 4, 5, 8, or 10 steps.
• Adjustable Auxiliary Device Jack Control. Control how your auxiliary device jack operates from momentary (for use with the FOXPRO Jack-in-the-Box Decoy) or latched (for use with other devices such as different manufacturers decoys.)
• Wireless Sound Transfer. After programming sounds into the Prairie Blaster, you will not need to use a patch cable to transfer the list to the remote. The sound list will be automatically transferred into the TX-500.
• Internal and External Speaker Control. Turn internal and external speakers on/off via the TX-500
• Mono/Stereo Operation. Select mono or stereo audio operation from the remote control.
• Mute Button
• Volume Up/Down
• Recall Button
• Instantly jump back to the last sound and volume level played with the push of a button!
• Operates on 3 'AA' Batteries
“It never gets easier, you just get faster”
