Some bloke No-Scope rifle sight.
Post by some bloke » 20 Oct 2014, 15:27
Another No-Scope rifle sight with an EJ230 camera inside.
https://www.youtube.com/watch?v=4Ky0SnK ... -OWKFJadkw
It can be used in a head up position - or a head down cheek weld position with the monitor about 10 inches from the eye, an earlier version is shown in this photo:
runs on two 18650 rechargeable batteries (not supplied) or 4 CR123 batteries ( I have not tried rechargeable ones). Batteries are accessed by removing the monitor which is connected via an (umbilical?) Servo cable:
This is how the monitor is fitted and removed:
https://www.youtube.com/watch?v=IliQEYh ... -OWKFJadkw
At typical subsonic range it rarely requires an illuminator to be used to spot then stalk up to your rabbits and sometimes even take the shot: Though there will be periods of very dark when an IR has to be used - and periods when you can see several hundred yards without an IR.
Few NV users using add-on rigs can imagine the covert capabilities of this rig at subsonic ranges without spending several hundred pounds.
You can expect this sort of advantage on a foggy night for example:
https://www.youtube.com/watch?v=t6nPsp8 ... -OWKFJadkw
And this performance in good moonlight conditions:
https://www.youtube.com/watch?v=VMrHaSI ... -OWKFJadkw
Any of the illuminators in my signature picture can be included with a scope mount for £40 if taken at the same time.
I'm slightly dyslexic so please expect to see a few edits if I notice I missed something.
thegogg
Re: Some bloke No-Scope covert rifle sight.
Post by thegogg » 22 Oct 2014, 07:38
PM sent
Post by some bloke » 25 Oct 2014, 11:33
I now have another 1.4 Cosmicar 75mm TV lens if needed - add £100 to the build. :angel:
The body is tidy except for this side - but the lenses are superb and actions are smooth etc:
Post by some bloke » 27 Oct 2014, 10:24
This now has a 100mm M42 SLR lens and weaver scope mount fitted - and has taken up residence on my LVSF in 17REM flavour. :angel:
