Camera lens wanted
gypo
Camera lens wanted
Post by gypo » 29 Apr 2014, 18:46
I have decided to build a spotter so im looking for a suitable lens if anyone has one for sale?
G
baffled
Re: Camera lens wanted
Post by baffled » 29 Apr 2014, 20:48
What sort of lens are you looking for?
gypo
Post by gypo » 29 Apr 2014, 22:55
SLR type I guess. I want to build a spotter.
Torchwood
Post by Torchwood » 30 Apr 2014, 06:27
If you looking for slr lens, 50mm would be fine, but need two adaptors.
42mm -- c mount
C mount -- m12 mount
The existing nozel on e700 would be too long and need to be trim back to get the right focal lenght.
I have a 50mm 1.8 if you want.
Uk supplier for m42 adaptor
http://www.scopesnskies.com/prod/148.html
C adaptor from sure24
Toni
Post by some bloke » 30 Apr 2014, 07:30
I think you want to be looking at between 1 and 2 times wider than the mag your riflescope is normally used at - because you have that for distance sighting and final identification/safety checks.
Have you already got your camera - if so what is it? I'm no good at viewing angles - but I think someone who is will be along soon.
gypo
Post by gypo » 30 Apr 2014, 08:49
Torchwood wrote:If you looking for slr lens, 50mm would be fine, but need two adaptors.
42mm -- c mount
Toni
Pm'd you
gypo
Post by gypo » 30 Apr 2014, 08:56
some bloke wrote:I think you want to be looking at between 1 and 2 times wider than the mag your riflescope is normally used at - because you have that for distance sighting and final identification/safety checks.
I'm thinking of something like this eBay no 300891660907
It will be to build a spotter
22-250jock
Post by 22-250jock » 30 Apr 2014, 09:06
Gypo
that's the same camera I had in my first spotter, good little camera for the money :thumbup:
had a 5-100 lens on it when I took these vids https://www.youtube.com/watch?v=NA9JZdi6InI
https://www.youtube.com/watch?v=tERaDm2hUVw
gypo
Post by gypo » 30 Apr 2014, 16:34
22-250jock wrote:Gypo
Looks good mate
G
gypo
Post by gypo » 30 Apr 2014, 16:56
Would i still use a m42 adaptor
With the camera that I suggested in the previous posts?
thanks
G
